Who builds the bets trans for the buck$$
fatride
Senior Member
Who builds the best Street/strip trans for the money??? And who stands behind there work???
if you would like to see the build sheet on our stage 1 or stage 2 transmissions go to ckperformance . com and click gm/2oo4r/stage1 or 2 and have a peek .also there is a story on the trans under tech articles and information section that was published in the gsxtra and remember, you are drawing on 18 years of experience. we also have a 2.84 /orv 2.52 first gear ratio 8 pinion planetarys,cryogenic output shaft ,and pro transbrake.as for who builds the best unit ,a salesman pedalling his product with mouths to feed will tell you anything to make a sell regardless of his pole positon(quality)so draw your own conclusions based on your research. as you know,i'm not the only one selling 2004rs.
I now for a FACT! that Bruce will stand behind his trannys and to me that weighed in pretty heavy when I made my desicion to go with Bruce at PTS http://www.2004rperformancecenter.com/
Thanks again Bruce. I just dyno'd on Sat. and put down 517ft lbs and 374 hp. Valve covers have never been off and still using the stock intercooler. Not bad for my little turbo.
Merry Christmas.
Thanks guys, Your input is great!!! The local guy out in Chicago is Jimmys Transmission. I had a few done by him, didn't last very long. And he had built them for a while. I will need one in spring so thanks for the help!
