who on here are running 75# injectors? with a modded ecm
REDS HOT AIR
Buick Tweaker
trying to see who runs these injectors beside me and how they work for you
72's are not the same as 75's so im looking for people running 75# injectors only
also if you would list who's chip your running
Last time I heard Steve Wood was running 75# injectors with a modded ECM and he is using Steve Yanklin's MaxEffort chip (he seemed to like the 75's).... Most of the guys that seem to be using the bigger injectors (55's and up) are having better luck using either the MaxEffort chip or the T+ w/ the Extender chip and 3.5" LS1 MAF setup....
HTH:)
I just installed a set this weekend. I have an ext. chip with T+, they run great. Better than my 50#er's. Hard to believe how big they are, streetability is awesome!
so i guess they can be tuned to be streetable...so far im not having much luck with fuel curve but i think it'll be doable with chip tuning
i guess everyone runs the extender and trans plus setup..
guess i'l add that to next years mods
REDS HOT AIR,
Red we have a car that has 75(s), we will be using a Brutal Six Fuel management chip - street & race. W'll give you a report once we have the results.
are you talking about the MSD injectors? If so, i'm running them and so are a few other people down here with modified ECM's
I am currently running Jay Carter Chips
Bob Bailey is running them also. All reports from him are that they run great, with his chips of course ;)
Red, I'm not running the 75(s), just the 72(s) ;) . But, I am still running the stk. MAF - car is running great on both street and strip.
Good Luck with your chip tunning
I am going with the 75's and the ME without the MAF. I have heard great things about this set up. I will get BoB B. to fix the ECM.
Red, have you ran the car yet with the new combo?
If my refined chip makes it here in time and nothing else breaks I should be laying down a pass at the import/domestic shootout this coming sunday at Maryland international raceway
I just got it going again friday night and wiped out second gear on sat.
I must say it fregging haulz ...
I have it on 28/12.50 et streets and its blowing them off thru 1st and when second bites its pretty nutz from there
only change to the motor was I did somemore porting on the heads (still stock valves) and the girdle
had my 9-11 converter restalled to 3400
notched frame to get the tires under it without rolling the lips :)
It lost a few #'s in the process and dont forget its got atr 3" single on it now (had 2 1/2 hooker d/p and duel 2 1/2 when it went 127 :eek: )
thanks for all the responses so far .. im tired as crap now i'll check them out when i get up..:cool:
