novaderrik
- May 12, 2004
or is there any place i can get the gaskets and seals to do it myself? i really do not want to spend the $$$ for a questionable reman from somewhere..
it's officially spring in MN, and as such, it's time to dust of the T Type for another summer of cruising. but the brake booster leaks- it has been leaking a bit for the last couple of summers. i have to put maybe a quart of PS fluid in every year, but the whole driver's side of the firewall and much of the floor is covered with a fine mist of oil that attracts dust and dirt, which is mildly annoying.
my two goals for this year are to fix that and to get the original trans back together and in so i can actually play with the boost once in a while. the junkyard Cutlass trans that's been in there since '05 just doesn't like boost all that much...
