Who sells the best dual electric fan in the market that is plug and play no mods to be make to the electrical parts or holes to drill, any ideas thanks..
You have to trim the ramchargers fan a little to make it fit, but you can't beat the price!! I have one and it works awesome. Damn shipping cost more than the fan!!!
The only trimming required on the Ramchargers setup are the tabs on the sides of the shroud. They're plastic, and very easily removed. Once that's accomplished, the shroud will fit tightly between the tanks. Get some foam weatherstripping from the hardware store, and stick it to the edges of the shroud facing the core. This creates a better seal, keeps the shroud from rubbing on the core, and makes the fit very snug. The plug-n-play adapter is worth the few extra bucks as well.
If you are doing this mod because of overheating, spend the $100-125 to get the radiator recored, if you haven't done that already. I have a front mount I/C and live in TX. After 15 yrs, I guarantee your core is clogged. Mine was about 75% blocked. After the recore and new fans, 100 degree temps w/the a/c on was no problem this summer.
