GnTooFast4u
- Jan 7, 2002
Went to the track with the Gn last night to get see what the car would run as it sat, I know the combination on it sucks but i'd figure it would at least run 14's. The car is an 85, the only mods are an either V1 or V3 intake(not sure which one) Pt-54 turbo, hotwire 340 Walbro fuel pump, atr 2.5" downpipe, with a 3" exhaust after that. 87 Ecm,(not sure what chip or injectors) Drag Radials. It was freezing cold last night and the car was running about 16 PSI, Fuel pressure was set at 40PSi (Vacuum disconnected and 58 under full boost) The Tps is set a 4.74 @WOT
I could only build about 3 PSI on the line, and every run was the same. 60ft-2.43, 1/4ET-15.4 @90.89MPH, It just seems like something is not right, that's a pretty low MPH (guess i;m just not making the power i need) You guys have any suggestions?
