SignUp Now!Well it's not bad gas,at half throttle it spits and sputters and get knock, just happened all of the sudden, I have 36# injectors what's the best fuel pressureCould be a number of things...If it just popped up suddenly could be bad gas. Need more info...
Just came to conclusion that when this happens the dash lights flicker and the scanmaster lights dim,go some sort of electrical issue.....any idea of where to start looking, alt. is only putting out 12.9 volts, what you think. I have had a bad maf before and it acts just like that,but now I think it electrical when lights dim when this happensFuel pressure vac line off... 43PSI per TT instructions, and then a 1+1 rise with boost after that.
Stock MAF yet? If so, good chance that's it.
Also noticed now if I hit the brakes fast and jar the car in the driveway the lights flicker and tries to go dead, this is going to suck tracing this down with no direction to goCheck all your grounds. Also, mine did something similar and actually had the positive batter cable rubbing on the exhaust manifold on the passenger side. Didn't notice it till it was dark out and I went looking for sparks and there it was lol
From where the harness plugs in its 12 but on the bolt on the back of of alternator I get 14, is that correct Dave?Check your battery connections for tightness AND corrosion. Alt only putting out 12 volts is bad. Should be 14.
Sent from my DROID RAZR MAXX HD using Tapatalk 2.
Chuck, you should have swung by the Sheraton Gateway at the airport last weekend. After you got off the stage at the virgin sacrifice, we could have went trolling for nice young ladies and checked their ring terminals for tightness.
Didn't think about that! Of coarse that's probably it cause I just put gas in it at a Arab station, thanks for waking me up
the ethnicity of the owners at gas station have nothing to do with the company they get gas from, just since they're arabic they get the crappier gas?why not i went to the black station, would that make the gas crappier? or the white station?
what are you trying to infer?
