Fuses blow from drawing too much current.
Could be shorted wiring or bad pump motor.
Running too long can be internal seal leakage or bad pressure switch.
Autozone reman. replace the whole thing is the easiest repair if you don't have the service manual or can't do the diagnostics necessary to fix it.
