- Feb 18, 2006
darkred87T said:I bought an LS1 MAF and translator for mine thinking it was the problem and it wasn't. Not that it's a bad investment or anything but your problem could be else where. There is a sure fire way to eliminate a vacume leak. With my 87, I pulled the rocker assemblie off to shut the vales, disconnected and plugged off the PCV line and took off the EGR and selaed off the port. Then, I got a 2" rubber cap to go over the throttle body. I then took an air hose and inserted it into one of the vacume lines with about 10PSI. I know this sounds crazy, but if air doesn't bleed off, you definitley don't have a vacume leak. I hope that made sense. Unfortunatley, my car seems to have good vacum so I probably have some other problem. I would eliminate the possibilty of a vacume leak first.
Nice! Now thats the way to find a vacuum leak. I had thoughts of doing the same thing. I planned on using some soap in a spray bottle for my leak detector.
