if not running a wideband ,the stock ac delco fs-20
my DFI was being run with a heated 02 sensor , casperselectronics.com has one with sensor ,
if running leaded fuel denso seems to hold up better than stock , get it from sparkplugs.com (about $40 for a pair shipped)
but i wouldnt want to try to tune DFI on narrowband O2 , a wideband should be used to get the car dialed in
if running a wideband , the LC-1 stand alone cable from innovative (about $179-199) which comes with a bosch LSu-4 wideband 5 wire sensor , would be better used with a gauge like the XD-1 which has recall (about $200-229) ,
or the innovative LM-1 wideband ($ 349 ,includes the bosch LSU-4 sensor) has ability to display and log A/F and lambda and with optional RPM module can log rpm and other sensors with 0-5v outputs , with optional AUX box it will log boost and egt and has an accelerometer built in ,
i run the LM-1 and RPM module
