SignUp Now!My logger is showing 14.1 at idle and 16.1 at WOT.If on gasoline? 10.8
I'm using a F.A.ST dual wideband.What wideband do you have? 16.1 is either wrong or your way too lean.
No but it sounds like my valves are rattling .Is the car popping or missing at WOT?
Adjust the fueling for a much richer condition and see if it goes away. Those fast widebands are good units, so you seem to be extremely lean at the moment. Surprised it hasn't went boom yet.No but it sounds like my valves are rattling .
I'm fairly new to using this wideband .How would I adjust the fuel curve?Adjust the fueling for a much richer condition and see if it goes away. Those fast widebands are good units, so you seem to be extremely lean at the moment. Surprised it hasn't went boom yet.
My fuel pressure at idle is 41. It does have a chip installed but it isn't labeled.I tried to get a user manual from the Fast website but no luck.A pic of the motor would answer a few questions since your new.
What chip do you have?
Find out your base FP and go from there. Should be around 43 line off and car running.
Here a pic of the motor.A pic of the motor would answer a few questions since your new.
