I know Andris ran 17x11 ZR1 wheels on his IROC. Had to use billet adapters because of the offset. But I'm pretty sure he didn't roll his fenders for the 315's. You won't need the adapters if you get a wheel with the right offset.
also if you're about the looks and not the performance the 10 bolts on a 4th gen have all the same mounting hardware but the axle tubes are 1/2 in shorter on each side........
Originally posted by trading t/a the 10 bolts on a 4th gen have all the same mounting hardware but the axle tubes are 1/2 in shorter on each side........
Originally posted by trading t/a also if you're about the looks and not the performance the 10 bolts on a 4th gen have all the same mounting hardware but the axle tubes are 1/2 in shorter on each side........
