Will this hubcentric adaptor fit?
Notice what the seller rights in tiny print:
"Note: These spacers do not fit all S10 and Camaro"
Well, guess what. The front hubs on camaro's and S10's are the same as ours. At least the one's on my camaro are.
"I Think" he means 98-05 2WD Blazer(F'd up sealed bearing and hub) and 4th gen F-body(same style F'd up sealed hub).:confused:
Wouldn't a 1" adapter push the GTA wheel out to far so it hits the sheetmetal? IIRC most people use a 1/4-3/8" adapter.
I have 1.25" adapters on the front and with 245s up front my tires rubbed. I changed the tires to 225s up front and the rubbing is gone. Just wish I could get my fronts on the rear to stick out a little more. 1" should be fine as long as your studs aren't hitting against the back of the wheel (ie if your studs are longer than 1" which i think they are? and you don't have indentations in the areas between the lug holes)
