Wilwood Dynalite Pro Series Front Hub Kit install
jwillettgn
Made some progress today installing the brake kit, it was alot more work than we thought though. Now we just have to safety wire the rotor and adapter bolts.
Going to pull the body off and clean and paint the frame next as you can see it needs it.
Jim
Mmmmm....pretty.
Got some specs?
Rotor dia?
It looks like it goes on around the stock spindle?
Do you use stock bearings?
Can't wait to hear how it performs.
Specs are here: Dynalite Pro Series Front Hub Kits
The kit comes with new wheel bearings. This is not a bolt on kit, we had to cut the old caliper mounts off for this kit to fit. We also had to drill the three bolt holes that hold the dust sheild on and tap to 3/8-24 UNF to mount the new caliper mount plate. This was not hard to do just took some time. It is listed as a race only kit but you know how that goes. It is suppost to knock 30 to 35 lbs off the front end. Our car is on a big time diet so every little bit helps. Still waiting on some more parts before we can put the drivetrain back in.
