Wilwood manual brake kit???...HELP!!!
monte87LS
Im trying to finish my Wilwood manual brake kit in my Monte but I need to install my Wilwood 10LB residual valve!...has anybody done this before and have pics of it installed...Ive done alot of research but I get too many different answers...where is the best place to mount this 10LB residual valve, Ive heard of people mounting them under the hood between the mastercylinder and the prop valve, that would be the easiest place to mount it considering im doing this in my drive way with no lift, then how do I know what size fittings I need...Wilwood was perfessional enough to make sure they tell you none of the inportant info when they sell the kit, like what size fitting needed, etc,etc, then i buy the residual valve from them and it dont come with the fittings needed???...now I need to hunt down fittings because there "kit" doesnt come with the stuff needed....:mad:
