Wilwood rear disk break conversion
87national55
I have been trying to find a “How to” but no luck. Anyone have experience installing??
Trying to figure out how much I need to cut off the ears and if I need to tap anything.
Which kit is that? Wilwoods instructions are usually pretty thorough.
Does it just use the two, or are you going to drill out some top holes, too? Or had you just not run through through when you took the pictures?
How are you doing / connecting the parking brake cables? I picked up an Autofab kit but the brass adapters don't seem to fit right. I haven't focused on the rear much since i got everything in, e brake cable connections are all that's left
Not ready for that step. Just finished assembling today.
