Ok so I got my GN back from paint and body on frame resto. Sweet! :biggrin:
I have been slowly putting her back together and got all the way to everything is done less the window regulators, door panels, weatherstripping... Sweeeet x2 :biggrin:
Well I accepted a another job- sweet
Sold my house in 15 days in order to move- Sweet
Then got laid off from the current job NOT SWEET
So long story now told, I have to move my GN ASAP to PA from VA.
Well I got the glass back together and the shims and adjusters on the regulator in with new motors too. I labeled everything on the doors prior to removal and reinstalled in the same order. The windows were loose and rattled before I removed them.
However, now paying closer attention upon reinstall, I think someone was in the doors before and had the shims/adjusters/stops in the wrong spots. So now the windows work but are not horribly out of wack, but they are anything to write home about. There are some small gaps that won't be able to seal out all of the wind/rain.
I was wondering if anyone has GOOD pictures of the where each shim and adjuster go and any tips on which shims/adjusters have the best effect for each movement... it will really help... G body Haynes manual really never address the adjusters. This would all help before I tear back in to her.
The car is going to make the trip as is and will be locked up in storage once I get up to PA until I find a new place to call home. Normally being a tech. I would pride myself in trying to figure out each window by myself, but I need some expert guidance and certainly don't have the time right now to fool with it. So any help would be key.
