Window Seals
aperrego
Drunk? I'll Check. :)
Can anyone tell me how to change the rear side window seals? I am striping the car for restoration and do not want to break them.. Also would anyone know the replacement part #s for the window seals/gaskets?
Thanks!
There are no seals. Factory just used butyl sealer. Quite messy to remove from the rubber seal that surrounds the glass. After removing mine, I didn't use any sealer when I replaced the glass. ;)
I'd be surprised if you could buy that gasket. Also, it seems pretty hard to remove. As I recall, I made a small attempt at it and it seemed as though it doesn't come off. If your rubber gasket is messed up, I'd suggest getting different side glass.
Well I was hoping to remove those windows as well to get a true paint without any gaskets/fillers/windows..
I'm not sure what you're saying........Just unbolt windows from inside the car and push them out. The glass and the rubber gasket around it come out as a unit. End of story.
my bad.. thanks.. I have not pulled the interior out yet. that is WEd Night ;)
THanks!
