Window switch not working?
simon930
When I got home I went to go put my windows up from the drivers side switch but neither the drivers or pasenger side window went up.
When I pressed the Switch on the passengers side the passengers window worked. What can be wrong with the switch?
Thanks let me know
It is more than likely a bad connection, as both sides are effected. Remove the switch and coat the pins with dielectric grease, reassemble and test the switch before reinstallation of the door panel. If the swich is bad our vendors have replacement components.
