GNONYX
- Oct 16, 2009
I started by replacing the intermediate exhaust pipes, muffler, and reused the original tail pipes
Replaced the powermaster with complete vacuum system, and I'm still working on them. I started by bleeding all brakes by gravity just to remove the old dirty brake fluid. Installed Russell speed bleeder, Bench bleed the MC, fresh brake fluid, and started to bleed the pass. rear. Only to find out nothing was coming out of the bleeder, I removed the bleeder clean it a bit and still nothing.
The bad new is now I have to replace the wheel cylinder, and reading how it's connected with a clip instead of two bolts. I replace the exhaust elbow/downpipe donut was damaged from moving back and forth when installing the mufflers system.
I couldn't figure where the ticking noise was coming thinking it was the donut, being I removed the throttle body to replace the shaft seal, and replace the oxygen sensor. Here I thought I was going to use a 7/8" wrench and the damn thing was so loose I removed it by just a few turns. Now I know where the ticking noise was coming from, and why the BLM was reading over 148.
I don't know if this is a winter maintenance or a winter project.I made a smoke machine and that's is how I found a major vacuum leak coming from the throttle body shaft seals, as this is the second time I replaced them.
I did found out these seals are not a direct replacement, and the following statement explains: The only available shaft seals for Buick GN throttle bodys measure 10 X 17 X 5mm. These are .010" oversize. ANSI Standards for these seals specify a maximum press fit of .0011" thousandths. For this reason you really need to enlarge the seal pockets to get a good seal there. Distorting the shaft seal will affect its function.
I used my Dremel with a sanding band and rotate in circle inside the throttle body shaft seal pockets, and it fit pretty good, but the true test is when I use the smoke machine.
The left oxygen sensor is what I removed and the right is Denso replacement, and the damaged exhaust elbow/downpipe donut
