stickybones
What?
- Dec 27, 2001
My intermit wipers don't work. Mist works, and so do the hi and low speed. Saw some other threads in the archives that says the "pulse" intermit wipers are controlled by some module in the cover. Replace the cover and my problems should be solved.
Well, how the heck do you remove the cover? Doesn't seem like it comes off with the motor in the car. Figured it was easier to just remove the whole motor and take the cover off with the motor outside the car. Undid the 3 bolts (that bottom one is a PITA) and the nut that holds the wiper arm mechanism on the motor. But I can't get the arm off the stud. It just doesn't release. I don't want to pry it off and bend everything all up. How do you get that arm off?
And am I on the right track here? Will replacing the cover assembly solve my lack of intermit wipers?
Mike
Mike
