Wiring CS2 front speakers in parallel
oops, yeah, that's right - parallel is stock, and I guess I need to wire them in series. So I guess the question is, the wiring should go plug to 3.5"+, then from 3.5"- to 5.25"+, then from 5.25"- back to the plug. Right? That's what my sketch shows. I just want to be sure that is right before I start hacking on wires.
John
your drawing is right.......i can build you a custom harness adaptor if you have time so you dont have to cut up your rare CS2 Y harness.........
