captndave737
 - Feb 14, 2006
Of course you can.  Depends how you wire them. I used the stock connector, pin A to provide power to the coils of both my fan relays.  The other side of the relay coils are  grounded.  I don't use pins B&C , ground and high speed signals.  When my fans run they are always on high.  One side of the relay contacts go through an inline fuse to the battery and the other side to ground. It's a pretty simple system.
Since I rebuilt my wiring harness I've eliminated all the high speed and delay circuitry from the system. I also cut off the stock connector and replaced it with a single pin weather pack connector that goes to the low speed fan relay. I removed all wires I don't use under the hood.
