Wiring question for a fuel pump and boost controler
larry33kc
I have a Fuel pump and Boost controler, and it need to be wired to a Tach lead. Where would the best place to wire that be? TIA
behind the alternator is the tach feed , should be taped to the harness along with the fuel prime .
the tach connector is a male spade , needs a female spade to connect
Yea I don't think I have that wire. My car is running BS3 and I think the harness has been cleaned up a bit. I have looked and haven't seen it. Is there any place else?
you can tap in at the ignition module harness
pin E , 5th wire from the firewall is tach out to the dash
