jpwalt1987
- Nov 9, 2003
Hey guys, I have been fighting a problem with the car not wanting to stay running. I thought that I had some bad gas at first but I drained it out and switched to another station. car seemed to be better for a little while but it is now acting the same way. I have a GEN 1 Big Stuff 3. I can increase the base volumetric efficiency to about 50 and it will stay running. That puts the AFR at about 10.5:1 at idle. You would think that it would be blowing black smoke at that AFR but it isnt. I have the base FP set at 45psi vacuum off and it drops to about 38 with vacuum on. I am starting to lean towards a fuel pump going out. It is an older paxton pump similar to the A1000 and -10 line to the fuel rail with 95 lb/hr injectors. It only has about 1200 miles on it. It was running fine and then one day...BAM run like poop!!
I have good fuel pressure though, that is why am not sure about the FP being bad. I am trying to think of other possibilities but am kind of running out of ideas. anyone? JW
![Mad :mad: :mad:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f621.png)
