captndave737
- Feb 14, 2006
My cruise has always worked except for when the brake switch was out of adjustment. If the light doesn't come on when you hit set/coast then I'd say it's electrical.
SignUp Now!Probably correct! Unless the bulb is burned out. I will focus on power first and see where there is none. ThanksMy cruise has always worked except for when the brake switch was out of adjustment. If the light doesn't come on when you hit set/coast then I'd say it's electrical.
Thanks for the tip. Shows how hundreds of heads are better than one. When I turn the key to "on" only the "service soon" "seat belt" and "voltage" lights come on. I have the electronic dash. Not sure where the cruise light would be on that. Hard to replace? What bulb does it take?you can see if the bulb is burned out by going to the bulb position on the ignition key.
The service manual shows it on the right side at the bottom. I'll have a go today. Thanks againI don't know where it would be on an electronic dash. I have the factory service manuals and don't think it shows it. Might be in the owners manual.
I can't imagine it would be hard to change. on the standard gauge package it's quite easy, pull off the trim and unscrew the instrument panel to get at the back. They're peanut bulbs. Don't know what the number is though or if they're the same.
Got any pics of the circuit boards? interested on the internals of it.The cruise doesn't see TPS. It only sees the speed sensor output and the brake pedal. So if the cable were disconnected from the throttle, and the car fell below the set point, the servo would WOT trying to get the car back up to speed.
Mine quit working a bit ago. Replaced the servo to no avail. Tried to replace the module, but can't get one new or reman. I did go junkyard diving and came up with three boards that might work. The one I have in now has the same P/N printed on the board, but several jumpers are in different places. It tries to work with that board. I can set it, and I feel the servo moving the pedal, but it doesn't move it enough to maintain speed.
I have good vacuum at the servo and the brake switch isn't the issue. Cruise light comes on and everything. It just doesn't yank hard enough. Haven't been able to tell if the servo is weaksauce, or I need a different module.
I may look into adapting a newer cruise setup. Parts for this one are just hard to get.
I have an AVC dash and have never seen the cruise bulb light up except for when I engage the cc.
Yup, it doesDoes your VSS have wires coming out of it?
