turbo96max
- Jun 6, 2007
Guys, I have put new plugs, tested with my friends wires, coil tested good, tried running car with the cam sensor unplugged, tried my friends maf, nothing doing
the car is not taking out timing (no knock)
have played with the fuel where o2 readings at leanest have been from 730 - 805, and still same breaking up
the car runs great part throttle, but full throttle i get what seems to be a one cyl ignition miss, the car still pulls, but its a constant miss. not backfiring.
what am i missing to check, can the o2 be bad? can the crank sensor act up this way? the car idles fine and it runs good makins power at part throttle, just doesnt like wot? the only code i have in 41 which started when i tested the cam sensor disconnect , which hasnt left, do i need to unplug the battery to clear the code?
