Wot Shift Points
boostmaster
OK after my low pressure, front pump situation, I put a new pump in and I have good pressure in all gears, over 200psi in all gears @ max TV. The tranny shifts fine in all gears but @ WOT it shifts from 1st right into 3rd gear and the car falls flat on it's face because the rpm's are way to low. Can anyone help me out with this one. If I manually shift it the car upshifts like it should. It only does it in D or OD. I don't think it's in the valve body because I swapped it out also when I changed the pump. The trans is a 85 BQ unit w/ a super servo and stock length 3 groove pin. Also I have adjust the TV cable to it's max and it made no difference.
