Would these tires and rims work
savagebreed
I seen some wheels for sale. I wanted to know if these will work without me having to roll fenders or get spacers. Thanks
Brand: WELD RACING Number of Bolts: 5 Material: Alloy
Width: 8J Bolt Pattern: 5 x 4.75 or 5 x 120.65 Structure: Two Piece
Diameter: 15 inches Offset: 12 Part Number (MPN): 96-57276
Tires Mickey Thompson part # 6653
26 x 10
Each individual Regal is slightly different as far as how centered the rear end is mounted AND also how centered the body is to the frame.. This makes it hard to give you a definite answer without measuring how centered your car is overall. But I will say most regals can fit a 26x10 tire. It also depends on the Backspacing of the rims.
Since they are Welds, I am assuming your choices are either a 3.5 or 4.5 backspacing. the 4.5 will probably require a least a small spacer, while the 3.5 may rub the fender lip with the 26x10 tire
I went with a 4 inch backspacing to avoid this problem, and it fits dead on in my 87 GN with a 26x10 tire. Since welds does not make a 4 in backspacing, I went with Centerlines instead.
BTW- You are going for a 15x8 rim, right?
Edit: I think thr 26x10 tire sould most likely fit... I had the 26x10 confused with a 275 50 15 tire that is actually wider than the tire you mentioned.
