would this 16" or 17" wheel fit?
XxDarkSidexX
Banned
1.) 16X8, 5 lug 5x4.75 pattern, with a 23mm offset?
2.) How about a 17X8, 5 lug 5X4.74 pattern, with a 20mm offset?
Ideally, you'd want zero to negative 15 offset.
Positive 23 to 20 offset with an 8 inch wheel will work OK in front, especially with aftermarket brakes (like baer or junkyard B-body 12" brakes).
In back, they will likely rub the frame hard, even in a straight line with anything more than a 245 tire.
