hey i think i have exactly what you are looking for. $6500 Just got it out this afternoon, and plan to have it all cleaned up this weekend. i have a brother in Ft.Collins CO that i plan to go see soon as well, I could deliver! Also it has made 3 cross country trips in the past year, and is very roadworthy with good gas milage, usually 24-27 doing 75mph.
pm if interested and i will give you my phone #. will have pics this weekend.
Gary
BODY
console is cracked on the base, inside the compartment.
needs headliner replaced
cruise doesnt work.
needs shifter handle
135k miles
small dents on trunklid, and one slight wave on passenger quarter
small rust spots forming on the bottom front corners of the doors
MECHANICAL
motor has NEVER been opened, headers leak
transmission (original) in need of a rebuild sometime, shifts fine, but getting long, and needs hardened stator support.
A/C does not work but complete
turbo exhaust housing has bad bolt hole
MODIFICATIONS AND IMPROVEMENTS
ALL suspension bushings replaced 3500 miles ago, POLYgraphite in the front and poly in the rear.
all new suspension parts except idler arm
new front tires, 275/50/15 BFG drag radials in the rear
UMI Performance rear control arms
XP fuel pump, ADJ. regulator, 36# bluetops, fuel press guage
Scanmaster 2.1
ALKYcontrol progressive alcohol system
3" single exhaust, cheap homemade 3" downpipe
TE-44 w/precision housing
K&N filter
3000 stall D5 converter
comes with factory turbocharger
