WTB 87 GN or WE4 -Texas Area
DiamondHill
in the market for a 87 GN or WE4 in or near Texas - 30-35 K price range . What’s out there ?
87 t Ltd. Lots of new and upgraded parts.
Was a joint project with my wife. She died. Car is almost done, too many memories. It has to go. Timm
602-376-5304 8 to 8 m-sat not around sundays
How much are you asking and location?
Phoenix,az. Area
Recent paint,pro built motor:
NEW PARTS:
New old stock heads
Wiseco forged pistons
Turbo rings
Scat forged crank
Comp street hyd. roller cam, lifters, springs, retainers, locks
Metalclad stem seals
Comp tru roller timing set
Ferrea valves
Harland Sharp 1.65 roller rockers
.080" moly pushrods
Hi vol oil pump
6 qt oil pan
70 mm throttle body and upper
60 lb injectors
Plug wires
T/A stainless race headers & x over
3" stainless down pipe
Dual 3" exhaust
Dyno Max super turbo muffs
9" rearend, posi, 31 spline axles
HD driveshaft
Alternator
A/C pump
Water pump
Alum radiator & fans
AXIS programmable system
Art Carr trans, convertor, deep pan, shift kit
Shocks, brakes, tie rod ends, ball joints, bushings, steering box, remote resevoir, sway bar links and bushings
Power seat transmission
Brakes and rear drums
Complete interior, carpet, headliner
240 fuel pump, lines, adjustable regulator
O2, TPS, MAP, BOTH TEMP SENDERS
62/62 TURBO
HOLLEY LED headlites
Power Master mini starter
74 OPTIONS ON SPID SHEET!
Window tint
Window motors
Heater/A/C motor and metal fan blade
Heater core & control valve
all belts and hoses, T stat
Wheels and tires
Motor & trans mounts
5th position body mounts
Rear seat X brace
MOTOR:
Bored .020 5 step plateau honed
BHJ decked, line honed, ARP main and head studs, billet center main caps
internally balanced
Heads and intake fully ported
Valves unshrouded and chambers polished
Oiling system completely ported/flowed
Perf bearings
Intake, block, heads and timing cover externally detailed
X over and down pipes freshly heat wrapped.
I know there is more but that's all I remember for now....
LESS THAN 100 MILES SINCE FINISHED!
Last memories of deceased wife, needs to go.
Asking $32k ( I have almost that much in parts and labor!!!I haven't advertised it yet.
Mr. Spool knows me and my work, PM him.
I will throw in a new Alky controls dual nozzle alky injection kit New in box.
I HAVE THE ORIGINAL TAKE OFF PARTS!
He who heasitates is lost.....
SOLD!
And I even decided to throw in some of the new but uninstalled parts too!
Mike is a great guy and has been treating the car with as much love, care, and new parts as I did!
It has gone to a good home!
TIMINATOR
Check the parts for sale section soon for a list of other new and lightly used parts that I didn't use.
As par for the course with my experiences with Turbo Buick parts and availability, even the pic is upside down!
I still have to put the new rebuilt seat transmission in and deliver the drivers seat. I still need a seat switch to finish it.
I'll pay ya for one if u have it. It is about 1 1/4" high and about 5" long.
An up and down flip switch in front and rear, and a 4 position joystick in the middle. 6 round pins on the back, I believe. Plugs into this socket. I'll call ya later.
THANKS! TIMINATOR
