- Sep 24, 2010
Like the Title says....
Let me know what you have.
SignUp Now!Nope. Can't justify that. And if that's the median price, they can keep 'em.Just seen a full champion for sale on FB for 2400….. lol
If you want one I understand but You dont need to port the manifold to run faster if that's the goalNope. Can't justify that. And if that's the median price, they can keep 'em.
Car runs low 10's already.
I just have a set of Champion fuel rails i'd like to put to work on a back up engine. They won't fit a stock manifold.
The on center isnt for stage 2 heads. There are no available efi intakes for stage 2 heads. The on center and off center are both for production style heads.you should be a little more clear on what you're seeking
champion made three intakes
- the stock intake that they used stock cores and milled the egr tower ,filled it and then ported the runners
champion offered 2 billet rails setups for the stock intake. one was for stock style bolt on fuel regulator the other for external fuel regulator
the champ intake has an engraved ovaled area with engraved serial number on the underside
- the race intake - off center (for production style heads like the GN1 -TA performance and the stock iron heads)
- the race intake- on center (for buick motorsports stage 2 heads)
the race intakes are new casting based on the BGC intake a
these intakes have no egr , reconfigured the injector angles and has a larger plenum opening requiring a unique longer plenum so these intakes were sold complete with billet rails and the plenum because the stock stuff cant be used on them
should note that champion race intakes could be ported to match a set of heads or ported for tall port heads
oops yes stage 2 on center blocks and TA aluminum on center blocksThe on center isnt for stage 2 heads. There are no available efi intakes for stage 2 heads. The on center and off center are both for production style heads.
