wtb stock valve covers
therookie
lookn for some stock cast aluminum valve covers. for a 3.8 (231) let me know what you have
trying to fit them on a carb turbo set up. since my stamped steel ones always want to leak
David
$50/shipped. Add $25 if you want the plenum also.
You'll need to get the right combination of valve covers,otherwise there will not be access to the oil fill hole.Here is a quote from Rich,on this subject
There is nothing that directly works.
On the passenger side, best bet is to get a 84/85 Turbo Regal valve coer. It will have no holes and the bevel back edge. 86/87 will have a breather hole in the front.
On the drivers side, a no hole cover from a 1985-ish FWD with a Buick 3.8 will work, but will somehow need an oil fill/breather hole installed.
84/85 covers
I have a clean set of 84/85 for $50 shipped.I think I have all the bolts too. Phoenix, Az. Paul 480-221-9572
