WTB Stretched Stock IC Brackets
Are these the same as the stock intercooler brackets or different?
I have a set of stock intercooler brackets if they will work?
They are suppose to be different from what I am told probably will end up having to have them fabbed
What brand I/C is the for?
I have a Mease stretched stocker and it uses the stock brackets. The drivers side is unmodified, but the passenger side needs to be cut out / notched so the longer I/C can go down past the bracket.
I believe there are only a few that use a completely different passenger side bracket.
It's a little hard to see the bolt head on the right, but you can see the ones on the left.
