WTT 2000 trans am 6 spd blk on blk 400 rwhp- FOR 87 gn
liv4gnz
i am from clifton nj and i would like to trade my personal car now for a 1987 buick grand national any condition or any mods done to it
2000 pontiac trans am
black on black leather
6 speed t tops
i baught the car march 2007 it was bone stock from an old guy from ohio.
i picked it up at bordentown auto auction in pa. the car was never hit no rust and always babied. i transfered the title to my friend for insurance costs but the car is mine and the title was signed by him back to me. i baught the car with around 78k miles
the currentt modifications to the car are, and the car will be sold as is with everything. plus all theh original parts,
these modifications have less than 10k miles on them so they are like brand new
-whisper lid
-green air filter
-slp longtube headers witht slp off road y pipe and slp loudmouth 1
-the air and egr system has been remmoved
-7.400 trickflow hardened pushrods
-duel titanium patriot gold valvesprings with seats retainers and locks and new valve stem seals
-ls2 timing chain
-comp cams custom ground 234,236 11+4 lsa camshaft
-new water pump
-new belt
-new power steerinig pump and pulley
-200 amp high output alternator from alterstart
-new exide extreme duty battary
-belt tensioner
-idler pulley
-ac has been removed but i hhave all the parts to give back to thte next buyer
-ls7 clutch disc,pressure plate, and ls2 flywheel, pilot bearinig,
-slave and master cylinder were new from dealer so oyou will not get the stuck pedaal like most of these 6 speed cars with thte drill mod done to it
-rear traktek tubular lower control arms and panhard bar powdercoated red
-eaton.auberngear posi unit with motive 4:10 gears in the rear end
-polyuerotthane trans mount
-c5 z06 18 inch corvette rims with the powder coated centers and chhrome rivets and lip fronts are 9.5 inches and rears are 10.5 inches
-4 new brand new tires front--sumitomo htrz II's 265 35 zr18 and the rears are firestone firehawk wide ovals weich are 295 35 zr 18
-spark plug wires and ngk tr55 spark plugs gapped correctly
-pro 5.0 shifter with umi short stick and black ball
-brake pads are new witth powerslot front rotors weich are slotted and cryogenically frozen option
-dynotne nitrous purge kit just for show this car was never sprayed.
-all four headlights are new
-side moldings were removed for the smoother look
-driver and passanger winidow motors
-stewert warner shift light
-2 new 02 sensors with hookoer 02 extensions
-5 percent front and rear tints
-front lowered 1.75 inches, rear 1.5 inches
-alluminum driveshaft
-transmission fluid has always been clean and always fresh with mobil 1 atf
-rear end fluid has always been fresh as well with lucas 85w90 syntehtic and with posi unit additive
-oil has been changed at 1500 miles with mobil 1 10w30
-the sound system is increrdible with a custom box weich sits on top of the hmp behind tthe back seaat weichj consists of 3 jl audio 10 inch w1's
1500 watt rockford fosgate amplifier
2 farad capacitor
monster /kicker wires
and a panasonic head uunit weich plays everything from sirious to mp3 to oipod
it comems with and ipod and the adaptter weich sits in the glove compartment and you control it at the headunit
has a remote and a bass controller up front as well.
i have performed every modification att my own personal shop weicfhh means this car is mechanic owned except the tune weich was done a tt performance in passaic nj, they tuned out the air and egr codes as well as torque management
bone stock the car put down 310 rwhp
as of rigiht now it puts down 393rwhp and 383 rwt and i have both dyno sheets
the modifications alone with labor are over 7 thousand dollars.
THE BAD
there is a key mark on the hood and on tthe passanger door
and the frornt bumper on the driver sidie front has a crack righth in front of the wheel.
that is it, everytthing else is flawless the interior is flawless as well
my name is bobby my phone number is 973 330 1874 you can call me anytime doesnt matter rhow late or early if i idont pick up leave me a message and i will get back to you and i live in clifton nj
MySpace.com - Bobby The Trans Am BETCHES - Photo 1 of 17
MySpace.com - Bobby The Trans Am BETCHES - Photo 8 of 17
