I think mine is actually a different issue. Mine seems to change on its own - cracking the throttle doesn't seem to make a difference. Hard to tell because the fast box was on someone else's car, so I hadn't had enough time to try to diagnose.
Razor, are you sure you don't have your close loop parameters set right? sounds like it's going into closed loop when you crack the throttle (as it should) and just needs some fine tuning on the open loop idle? Not knowing anything else.. it seems like you're then meeting your RPM threshold for closed loop and that's what it's doing.
This is what I got from Fast tech support:
Go into your dashboard set-up and add UEGO(V), UEGOS (R), AND UEGOS (S). Disconnect the o2 sensor and turn the ecu on, and look at these values. It should be V=3.51, S=1.02, R=4.98. If that is ok, the ecu is just fine, either the 02, or its harness may be at fault.
