How are you guys using it? Cant it just turned be on and off through the outputs. Is the power adder function needed? This is with a wet shot. Mine seems to have the power adder input enabled it it screws up the target afr through out the entire run. The first one is with nos and the second is without no other changes. The nos turns off at 12psi
