TIMINATOR
- Jan 26, 2020
One of the things we did to get more top end AND mid range, was to use a higher lift, longer duration cam than was normally used for the convertor/ gear combo, and advance the cam 4 or 5 degrees. That allowed higher flow for the top end charge, and we had the earlier intake closing from the advance to help the bottom end.
Then Comp cams came on the scene in about 1976, with tighter lobe centers, faster ramp rates, and higher lifts, and we gave up on "the old ways" and bought Comp cam products.
Although Crane, Isky, and Engle, had a SMALL selection of "good lobes" back then too, most were "old school."
Me and my cam analyzer still keep looking for better lobes, but Comp has the best selection so far. Call and ask them to sell you a "lobe library catalogue."
It only list lobe family groups, but it is thick as others entire catalogue. It has no instructions, but does contain info on intended usage of ramp rates.
I'll dig out some cam cards for a comparison, and post later.
TIMINATOR
TIMINATOR
