TURBOPOWERED68
David
- Jan 31, 2006
turboskylark
1-i took the easy way out and gave caspers some money for this Casper's Electronics, Inc.: 84/87 Dash Harness Mate
2-i used the GN mounts top and bottom. For the bottom ones I just had to drill the holes on the frame.
3-you will need to have some power steering lines made up with the correct fittings for the steering box.
4-on my car I had already a 2004r so no problem with that. But if your car has a PG the 2004r would fit with ZERO Mods. The only change is the addition of the D-tent Cable.
5-the fuel system is completely custom made. But again I gave caspers some more money for a plug in dash to fuel tank Harness. Then I added the Hot Wire kit.
In the engine compartment every thing fits pretty close to an OE GN
Take a look at my pictures if you have anymore questions just ask I am here to help
