nothingman
- Mar 24, 2012
After rebuilding the carb and turbo, removing emission, cleaning, etc. etc.... I've been driving my 83 T for about 2-3 weeks, only about 50 miles a week and not beating on her either. Maybe a brake torque or two. I checked the trans fluid a few days ago and it looked a little low so I added less than half a quart which brought it up to full... didn't realize till later that the car was not level and the land was leaning to the drivers side so I over filled the trans but not by a lot. Must have been a day or two later that the trans wouldn't shift into 3rd or overdrive. Remembering my brake torque burnout a few days earlier I thought maybe the trans tossed the governor spring so I dropped the pan this morning and no spring in the pan... Plus the fluid was not as dark nor did it smell as bad as I'd expect if the clutches were burnt. I've attached some pics to show the fluid, filter and trans with pan and governor removed. Also while I have the pan off are there any upgrades I can do if the repair is easy enough? I am under time constraints as I leave the state in about a week and won't be back to my t-type for about two months
Haven't done much trans work myself and I don't have the access to a shop or the money for a shop to work on it, just a carport in a shitty neighborhood. Any help would be appreciated, thanks folks!
