83 Oldsmobile Cutlass Cruiser Wagon
6-21-08 Update
engine is almost done still need IAC sensor,spark plug wires, oil return tube and a starter, i sold my bowling green stock stretched and will be running a GN1PERFORMANCE front mount archie sponsored me some hoosier drag slicks 28x10 so i got those installed on the drag wheels today, heres a couple of pictures
7-9-08
The engines finally done!! heres a quick sum up for you
109 .40 trw pistons stock internals
steel mains from fullthrottlespeed
INNOVATIVE T70 TURBO w/turbonectics boost controller
214/214 erson cam
60lbs injectors
GN1PERFORMANCE ported and polished heads and intake
GN1PERFORMANCE front mount intercooler
high amp alternator
mini starter
160 t state
kenne bell AFPR
GN1PERFORMANCE headers with 46mm external wastegate
GN1PERFORMANCE 3" DOWNPIPE
stock ported throttle body and plenum with rjc plate
rollmaster timing chain
Z06 MAF sensor and translator +
stock fuel rail upgraded for race fuel lines
the motor will be going in withing the next 2 month,now i have to focus on the tranmission
7-11-08
i got the buckets seats in their off a 30th ann. camaro just need to find a center console now
Very nice:biggrin:
A stock gray cutlass/442 console would probably match pretty good
I wish I had the $$$ to do this to my wagon, still need to finish my 64:frown:
8-11-08
just came in today my new aeromotive a1000 fuel pump, still need to get the filter and the rest of the fittings and fuel lines
not trying to steal this thread...
here's some pictures of my 83 Buick Frankenstein...
still in progress..
Exterior:
2 door front end, t-wheels, roll pan, sport mirrors, turbo hood, rear side markers shaved.
will be Maaco'd white; it's original color
Drivetrain:
67 buick 340-4 v8, stock rebuilt th350c, stock 7.5 308 non posi rear
Interior:
83 camaro buckets, t-wheel, cutlass console...
will be for sale eventually/now (if anyone would want this hot mess)
Ian, was 83 the last year for the Regal wagon? Also were you going to make this into a drag car? I see the HVAC is removed.
Yes, I believe they stopped all G-body wagons in 83? correct me if i'm wrong. for the regals I think they only were made in 82 and 83.
My car's just going to be a nice cruiser; I can't see it running any faster than a 15.5....as for the A/C, that was already gone when I got the car, I wanted to try and keep the heat but....oh well.
You might be right, as I know the Malibu wagon was last made in 1983.
I kind of wouldn't mind finding a G body wagon and dropping in an LC2, with a/c to boot then tune it to run 11's. :cool:
Yeah,
I was planning on dropping a turbo motor in this, that's why I bought the car...but the deal fell through. Anyway, I bought the car, and had the 340 out of my 67 to drop into it. It still should be pretty cool.
The Regals were made in 82-83, back in I believe 78-80 they had the wagon, but it was a Century with the single headlights. I saw an 80 in the junkyard where I bought my Regal. I was going to buy that one too, then I looked at the other side. Rear quarter all smashed in. :frown:
update 9-7-08
marred4life wanted me to post these for him since he is no longer a member, as of today the motor is in, the intercooler is bolted down,the fuel pump is mounted but will provide pictures once hes down with the lines and fittings
he had to make a custom bracket for the p/s bottle and relocated the battery to the passenger side, the shield for the a/c is on order and the dump tube for the waste gate is on the sump tank was done over at gn1performance
update 9-22-08
fuel system is complete,engine wiring harness is 95% done,added oil and primed engine also added comp cams engine break in additive,and the intercooler pipes are on they'll be getting powder coated very soon
update 11-3-08
we worked out the bugs with the help of our good friend petesgn and finally got it fired up today and i must say it sounds great....still need to get a 3.5 downpipe, radiator,hoses and different intercooler pipes to clear my 4" cai
well shes on the road now but the stock th350 trans is about to take a sh!t so i gotta get started on the 200 but that will take a while...i got a custom 3" single shot after the 3.5 cutout made from my local muffler guy and its so quite these slow corvettes wont no whats gonna hit them:biggrin:
