marred4life
Banned
- Mar 15, 2002
race gas and alky for me, alky just to drop the temps down
Not everyone has or needs a FAST system to run 113mph.
Anyone that can tune these cars can run any type of fuel and additive and make them perform.
Many can't get one tune right let alone two or three.
I like the easy daily driver and one tune concept.
Works well in both practice and theory.
And I have a collection of old replaced O2 sensors as well, but I think all mine are still good. :biggrin:
I haven't touched my fuel pressure regulators in either car, other than once
a year to make sure they are spot on 45psi., for about 8 years.
Haven't touched my headgaskets in 20 years either.
I am happy with pump gas and alky., I think that is what pizzes off most race gas users.
Either that or burned fingers from replacing O2 sensors all the time. :biggrin:
If you do a search with my user name, you'll find a similar thread where I looked around and found some research numbers on different distillates, and xylene kicked the ass of every other one (alky, methanol, etc) by a huge margin, in every respect thats important to us...there were like 3 different types...I think meta-xylene was the best. I want to try it but Im worried I may damage the system. It may be too corrosive to rubbers and plastics.
As for "which is better", thats a question that cant get far. Thats like saying which is better, a 747 or a cesna...they both have their intended purpose. But what do you need to do? Go cross country or 1 state over? How many people are flying? Whats the weather like? In the case of boost, you need to squash detonation/pre-ignition. Can high octane race gas do it? yup. Can alky injection do it? Yup. Can either system fail? Yup. Does 1 system provide more benefit than just octane increase? Yup. Alky does. The evaporative effect of the mist super cools the intake charge extremely fast, creating not only a draw on incoming air (more dense intake charge is the result), but a high octane fuel supplement. Detonation/pre-ignition can be squashed through a colder intake charge AND higher octane. Alky provides both. High octane fuel only does 1. But tuning alky can be tricky as o2's will have to be interpreted differently and you may need EGT's to tune it right. Also, a separate nozzle sprays in the alky in, in a sloppy way. High octane race fuel is precisely injected into each cylinder.
OK i understand that the alky is a cooling agent to help the incoming intake charge temps down. you stated that the alky evaporates. so i assume that it evaporates from a mist into a vapor if i'm understanding you correctly. well how does the alky when it evaporates into a vapor raise octane?. I would think that it would have to be a liquid to mix with the actaul fuel being sprayed from the injector to raise the octane.(kinda like adding a gallon of xylene to your gas tank.)
That was his white one??
Yep....
Saw it in BG the year before last when he brought it...... someone got a sweet ride.... it was as clean as you would expect for a 30,000 mile car... much less a 135,000 mile car... that thing really was detailed out nice.
Yeah I thought so. There must be something about stock turbos, stock unopened blocks, alky kits and white cars.
Let me throw myself under the bus here...
I can run 21 PSI on straight 93... .
