I'm all for a class for Hybrids as I've posted in another forum.
You all can go round and round about what is/isn't allowed.
I just want to be a part of the Hybrid class regardless of where you put me.
I'll just be there for the fun...
Well put.. could not have said it better!
Scott~
Well cheese here is your chance, we can break the class into two groups. It could be the "Street" portion of the class which will use the first set of rules we posted (That part of the class is set and is a definite.). We can also have an "Open Comp." portion which could use the following rules, or should I say lack there of -
Hybrid Street Class (Open Comp.) – HSC (O.C.)
General
• Heads-up 4-tenths pro tree start and pro ladder. (1 vs 16, 2 vs 15, 3 vs 14, 4 vs 13, 5 vs 12, etc....)
• No peer technical inspections relating to safety equipment rules by class participants or peers, Beech Bend Raceway track safety technician personnel will make all rulings on track safety related items.
• Winner and runner-up are subject to re-tech immediately after final round or at any other time.
• Any entrant caught trying to deliberately break the rules will be disqualified from the HSC class.
Body
• Any mass production model from any manufacture is allowed.
• Any Regal entering this class cannot have been originally equipped with a turbo Buick motor.
Chassis
• Tube chassis are allowed.
• Any suspension setup is allowed.
• Cars must pass track safety inspection (Helmet is required).
• Car should possess all applicable safety equipment for potential ET/speeds attained.
• Drive shaft safety loop required.
• Driver's name and club decal on side/quarter windows allowed. Sponsor/vendor decal is acceptable on the rear window.
Engine
• Any Buick or aftermarket Buick style V6 block and heads.
Turbo
• Any configuration of 3 or 4 bolt turbo.
• Twin setups are allowed.
Intercooler
• Any intercooler setup is allowed.
Engine Management & Fuel System
• Stock ECM or aftermarket DFI system allowed.
• Any fuel injectors are allowed.
• Gasoline (Race and pump fuel.) as well as alcohol injection allowed.
Engine Compartment
• Any engine compartment dress up allowed.
• Any type electric engine cooling fan required.
• Any radiator allowed.
Transmission
• Any transmission allowed. ( Jeffco, Lenco or Liberty type transmissions are allowed. )
• Shift assistance such as air, gas or electronic solenoid operated shifters allowed.
• Any size torque converter or clutch acceptable.
• Any transmission oil cooler and pan allowed.
• Trans-brakes, two-step and other launching devices are allowed.
Tires & Wheels
• Any size slick or D.O.T tire is allowed but must be in good shape and capable of withstanding speeds achieved.
• Tires may be screwed to the rim.
• Any wheel may be used.
Power Adder
• N2O allowed.
Jim C.
Folks were raising h*ll about the rules being too stringent so we will have the above set for the "Open Comp." sub-class. As you can see there really are no rules. If both have a great turnout then we will keep them both, if one is severely lackin more than the other then the better of the two will stay. I can tell you this though - If there isn't a decent turnout I will be hard pressed to have any ammo to push for a second year so let's have a good showing.
Jim C.
