87we410877
- Apr 5, 2005
I don't understand something on one of your steps.
You said you put all the shims on the cam button, found end play at .018 so REMOVED a .010 shim and ended up with .008.
If you removed a .010 shim you'd end with .028 thou clearance.
Did I miss something?
Sorry about that. There were so many steps in between that i tried to simplify it for the reader and i goofed up. What i did was, Started with all of them on, Removed a few and ended up with .018. Then i ADDED the .010 shim and came up with .008". Sorry about that.
Here are some pics of the motor in the car. Camera is a POS but you can make out some of it. I have to do some under hood cleaning and get my over flow for the radiator in there. The first is just the engine bay.
