F flyhigh Member Joined Jul 22, 2014 Jan 15, 2016 #1 t type would not start no fuel pump gray wire would turn pump on car started went to f p relay on fender jumped center pin /pin in middle drove home thanks again no tow truck Earl
T TURBOPOWERED68 David Joined Jan 31, 2006 Jan 15, 2016 #2 And this is why i still have my pressure switch connected and never leave home without my AAA card.
B BOP4ever Member Joined Jul 6, 2007 Jan 16, 2016 #3 What do you mean by have pressure switch wired up? What pressure switch? How does it help?
B Boost231 What's An Intercooler Staff member Joined May 26, 2001 Jan 16, 2016 #4 Oil pressure switch. It will bypass the fuel pump relay when it sees like 8 to 10psi of oil pressure.
B BOP4ever Member Joined Jul 6, 2007 Jan 16, 2016 #6 Figured that was it. I think mine was removed to screw in the sender for the gauge. May need to T it in and put the switch back !
T TURBOPOWERED68 David Joined Jan 31, 2006 Jan 16, 2016 #7 I have two OE "T"s in place keeping the pressure switch and the gauge sender
T TurboBuRick Moderator Staff member Joined Feb 18, 2006 Jan 17, 2016 #8 flyhigh said: how long can I run jumper relay 5 day commin Click to expand... As long as you want.
