Will post here in hopes the Bob or somebody with some first hand experience knows the answer.
Does anyone know if the Extender-G chip requires the 4th gear indicator signal form the transmission in order to lock the TCC at the programmed mph?
I have the chip selection set to lock at 45mph, but it is not locking now after getting a new Lonnie Diers trans, my engine builder told me the Lonnie does not put the electronic switch back in most of the time that sends the 4th gear signal to the ECM.
So wonderign if the chip requires this signal in order to lock the TCC.
I am not seeing the 4th gear indicator on Direct Scan light up either. I can manually lock the TCC using a switch on the ALDL and it locks up then just fine.
