Haha
Less things being used, means less things that can break or need maintenance
Or offer decreased weight.... depends on how you look at it. LOL
Thats just the weight in his cranium...With all that junk removed, JD is only 50lbs heavier.
I am a KISS person . Old people don't like all this wiz bang cool guy stuff![]()
If in fact TAI races THS The tree will be a .500 sportsman tree..........
Jimmy you should pull your heads and bring them up to CT for a little tweaking and we can raise the mass efficiency peak up a couple hundred rpm with a couple other small things. Might as well. You can move up a couple more places while retaining iron heads then give them a real treat next year.
109 block.. who?Need to correct that chart, especially at the top. There are quite a few 8 sec E85 cars. And E85 = pump gas !!
