RmvBfrFlght
- Sep 28, 2007
Just a question on this....Does anyone have measurements on the ideal location of where to cut this access panel opening?
Here is where I did it. The cuts are highlighted in red. The penciled circle with the hole in the upper left is were the sending unit is. Need to cut further to the right then the left for access to the fuel lines.
Cutting via a cut-off creates a lot of steel dust, hence the newspaper to contain it. Also blew off the top of the tank when done with an air hose.
I also recommend that the tank be dropped down some via the front retaining bolts. Don't need to remove the bolts, just loosen as far as possible to give more room between the truck floor and the fuel lines.
RemoveBeforeFlight
