Give me your guesstimate
SloRegal
If weather permits I'll be heading to the track this weekend. .
Mods are: TE-45a, 72lb injectors, ME-R with 24* timing, FMIC, 204/214 cam, P & P stock heads with bigger valves, built tranny with 3600 stall conv, airbags in rear, 275/60 MT Drag radials, C-16 race fuel.
I think I listed my main mods..LOL! Plan on running the turbo around 26 to 28psi. I'm in the Houston area. What do you guys think I would run?
Carlos
Your combo is almost identical to the one on my last car. It went 11.0 @129 leaving with no boost on the stock bottom end.
I'm sure if everything is dialed in you could see 10.50 -10.70 @ 125-128 mph
BTW - This turbo starts to come alive around 25PSI, get ready to change your shorts:wink: Good luck and start off with "low boost" as always!
Tune, Tune, Tune! Let us know how you do.
