went down to Silver dollar yesterday....the weather was perfect low to mid 60's and it was not crowded at all. I wanted to make some passes to see how my new converter performed since getting reworked. I installed a new PTC last season took it to the track at the end of the year and the car slowed down a lot. Took the converter back out and sent it back to PTC. They made some adjustments and the car has felt great on the street.
I wanted to see what I could get the car to do on pump gas only since thats how I roll on the street....I have an alky system but need to get a controller. So my first pass I left soft basically no boost stall maybe 1 psi just a shake down run it ran 12.42 @109 this was 17psi
I reviewed the log and it was clean so I gave it a few degrees and left at 6psi....the car hooked did a 1.60 60' and 11.80 @112.5 still at 17psi I was very happy at this ponit!
reviewd the log still clean and gave the car a lil more timing.....this time I wanted to leave hard...I was able to hold 10psi but as soon as I let the brake go the tires went away real bad........
Made another pass this time the only adjustment was dropping the air pressure in my tires.....10psi launch again same problem blew the tires off.
At this point I was thinking it was the track because some other guys were having problems too....made another pass did not change anything lowed my launch boost to 7psi when I left it slightly spun but I drove through it with a 1.78 60' and a 12.0
I was done it just was not gonna hook...either way I was very happy....I think that 10psi launch would have been 11.6ish if it stuck....but still I am tickled for an 11.80 on pump gas @17psi
